It seems the iTunes addon I’ve been using for the past few years no longer works,
does anyone have a recommendation for an alternative podcast addon please?
first hit on a google search:
Thanks, but I was hoping for something like the iTunes addon which I can just search for a podcast then add it to my shows, rather than having to generate my own .xml files
From some further googling it does look like Itunes or AudioPodcatcheher are the only options. The on going issue is being discussed on the kodi forums:
https://forum.kodi.tv/showthread.php?tid=143064&page=8
Last update was before Christmas, but any fixes or workarounds should be posted there.
Thanks Tom.
