Just a quick update: I just updated to the March update of OSMC and the issue persists. The kernel is still 4.19.55-6 so I’ll sit tight until the new kernel is out.
There is no new kernel yet, so this is to be expected.
With the release of the new update and the push of the new kernel yesterday. I updated my system and rebooted and sadly the issue persists.
Any thoughts on what I should try?
I don’t have a POE hat, so can’t test anything myself.
However, the thread linked to in post #5 has some more recent entries that might be relevant.
In addition, you might find something useful in https://github.com/raspberrypi/linux/issues/2715
Did you check the trip points in the forum post?
Doesn’t look it will be a kernel issue then.
I figured I’d respond to you both in one post. I reviewed these two locations:
I attempted many of the suggestions posted and to no avail. Based on what I was reading I set my config.txt to the following:
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
gpu_mem_256=112
gpu_mem_512=144
sdtv_aspect=1
dtoverlay=rpi-poe
dtparam=poe_fan_temp0=55000
dtparam=poe_fan_temp0_hyst=5000
dtparam=poe_fan_temp1=66000
dtparam=poe_fan_temp1_hyst=5000
dtparam=poe_fan_temp2=71000
dtparam=poe_fan_temp2_hyst=5000
dtparam=poe_fan_temp3=73000
dtparam=poe_fan_temp3_hyst=5000
After I ran a shutdown -r now and after it came back up I ran vcdbg log msg and saw that it loaded my overlay and dtparam’s
002468.000: brfs: File read: /mfs/sd/overlays/rpi-poe-overlay.dtb
002494.917: Loaded overlay 'rpi-poe'
002494.987: dtparam: poe_fan_temp0=55000
002495.667: dtparam: poe_fan_temp0_hyst=5000
002496.365: dtparam: poe_fan_temp1=66000
002497.103: dtparam: poe_fan_temp1_hyst=5000
002497.852: dtparam: poe_fan_temp2=71000
002498.631: dtparam: poe_fan_temp2_hyst=5000
002499.429: dtparam: poe_fan_temp3=73000
002500.258: dtparam: poe_fan_temp3_hyst=5000
I did take a look at the trip points and as the pages state, they are reverse but the order should not matter:
tail /sys/class/thermal/thermal_zone0/trip_point_?_temp /sys/class/thermal/thermal_zone0/trip_point_?_hyst
==> /sys/class/thermal/thermal_zone0/trip_point_0_temp <==
73000
==> /sys/class/thermal/thermal_zone0/trip_point_1_temp <==
71000
==> /sys/class/thermal/thermal_zone0/trip_point_2_temp <==
66000
==> /sys/class/thermal/thermal_zone0/trip_point_3_temp <==
55000
==> /sys/class/thermal/thermal_zone0/trip_point_0_hyst <==
5000
==> /sys/class/thermal/thermal_zone0/trip_point_1_hyst <==
5000
==> /sys/class/thermal/thermal_zone0/trip_point_2_hyst <==
5000
==> /sys/class/thermal/thermal_zone0/trip_point_3_hyst <==
5000
They also align with the dtparams I set in config.txt
I even went so far as to install on a separate SD card a clean, most up-to-date OSMC install and a clean, most up-to-date Raspberry PI OS to see if that changed any behavior.
For OSMC behavior was identical to my existing system but for Raspberry Pi OS after booting the fan kicked on and stayed on during my testing. I did notice that in the config.txt file for Raspberry Pi OS there is no mention of the POE overlay but the fan worked regardless. I even went so far as to copy the rpi-poe.dtbo on the Raspberry Pi OS renamed it to rpi-poe-overlay.dtb and replaced the existing file on my OSMC system but after a reboot there was no change in behavior but it did load the .dtb without complaint.
I also utilized dtc to alter the cooling-levels on the OSMC .dtb to a recommended setting but that also seemed to not alter any sort of behavior. I will continue to play around with customizing the rpi-poe overlay but I figured I give you both what I have looked at so far.
Good work.
We have come across situations on OSMC where the GPIO pins weren’t working and it turned out that there was no gpio group on OSMC, but there is one on Raspbian. That was resolved by a change in the udev rules so that, rather than creating a gpio group, the osmc group was given access to the necessary hardware.
It seems that the PoE hat uses I2C and I see that my Raspbian Pi does have an i2c group, whereas OSMC doesn’t. It might not be the source of your problem, but it’s still worth noting.
Doing some further searching, I came across this: i2c - PoE hat fan activation on OS other than Raspbian - Raspberry Pi Stack Exchange. Perhaps iyou will find something useful in it.
Thanks for the kudos, I think we are getting closer to the culprit!
What you found is exactly what I was suspecting of something additional needing to be added but I just didn’t know enough to say anything substantial. I did create that udev rule and nothing changed. Though that post got me thinking, I noticed that OSMC does not have a /sys/class/thermal/cooling_device0 symlink or base location at /sys/devices/virtual/thermal/cooling_device0. I was operating under the incorrect assumption that thermal_zone0 was some sort of artifact with a different name but looking at the Raspberry Pi OS system both exist:
ls -l /sys/class/thermal/
total 0
lrwxrwxrwx 1 root root 0 Jun 9 15:18 cooling_device0 -> ../../devices/virtual/thermal/cooling_device0
lrwxrwxrwx 1 root root 0 Jun 9 15:18 thermal_zone0 -> ../../devices/virtual/thermal/thermal_zone0
And as that article alluded to, I checked the types of both and they are different:
tail /sys/class/thermal/cooling_device0/type /sys/class/thermal/thermal_zone0/type
==> /sys/class/thermal/cooling_device0/type <==
rpi-poe-fan
==> /sys/class/thermal/thermal_zone0/type <==
cpu-thermal
For comparison’s sake OSMC’s /sys/class/thermal looks like this
ls -l /sys/devices/virtual/thermal/
total 0
drwxr-xr-x 3 root root 0 Jun 9 08:37 thermal_zone0
And with the expected type of cpu-thermal
cat /sys/devices/virtual/thermal/thermal_zone0/type
cpu-thermal
So I think the culprit is the cooling_device0 device missing on OSMC installs. Now solving that is out of my realm but if there is any material I can review that could point me in the right direction, I am willing to test out my theory.
There might be a CONFIG option in the kernel that needs setting.
Ok I’ll poke around but admittedly I am out of my depth on kernel building but at the very least I should be able to do a compare between what the kernel config is on OSMC vs Raspberry Pi OS.
Hmmm. Found this on Raspbian**, but not on OSMC:
CONFIG_SENSORS_RPI_POE_FAN=m
** Apparently now called Raspberry Pi OS.
Further info: Add rpi-poe-fan driver · raspberrypi/linux@6bad15a · GitHub
Good spot. I’ll kick off a new build with that change shortly.
Thank you so much Sam! Let me know when it is available and I’d happily test it.
Also, thanks @dillthedog too for discovering the lead!
I just wanted to follow up on this to see if we have a recommended path forward.
Thanks!
Unfortunately, I can’t find any kernel patch on the OSMC github repo that includes the configuration option CONFIG_SENSORS_RPI_POE_FAN.
You need to wait until after the Buster release
I figured as much, don’t blame you for focusing on the much larger and impactful release. Thank you both for checking in and best of luck with Buster!
Just a quick update, I went ahead and gave the Buster repo’s a try just to see any of the slew of new updates changed anything regarding the POE fan but sadly it did not. Still no, cooling_device0 in /sys/class/thermal/
I will wait until the offical release of Buster before I try picking this back up on this thread. Thanks guys!
It will come in the next major kernel update, which will likely be 5.4 based.
Sounds good. I’ll wait until the testing announcement for 5.4 to investigate further, which I assume will be a bit of time from now. Thanks as always Sam.
