Hi all,
I’ve added to my raspberry pi 3b+ the new official PoE Hat.
According to the guide on the rasperry pi website, the cpu fan should run automatically when temperature is above 50 degrees, my raspberry pi is well above that and the fan is still not working.
I’ve already tried to update/upgrade, only thing I didn’t try is rpi-update because is not included with osmc.
it works fine when I use it on another Raspberry pi with the official raspbian OS.
Additional information
No modification to the main Raspberry Pi board is needed for this product to work. Please ensure that your Raspberry Pi’s software is up to date for all functionality to be available. The PoE HAT is fitted with a small fan that is controlled by the Raspberry Pi via I2C. The fan will turn on and off automatically depending on the temperature of the main processor on the Raspberry Pi.
It’s using POE with the official hat for power, but the fan never comes on when I am running OSMC. For now i’ve taken the cover off of the case to help cool it. I confirmed that using a micro sd card with Raspbian the fan turns on immediately and cools the CPU down.
Add the following line: deb http://apt.osmc.tv stretch-devel main
I was able to get the updated version, the fan didn’t come on while playing a movie, I’ll let it run for a few hours to see if the tolerance is a bit different.
On my /boot/config.txt I removed the dtparam that I had added. I can wipe my microSD to a clean OSMC image and do the update to the 4.19 kernel if you’d like.
