I recently received my Vero 4k and I’m experiencing really poor image quality. Especially pronounced when there is a lot of movement against a black background you can see “trailing/ghosting” behind the movement. I’ve found that disabling hardware acceleration solves this problem but instead introduces stuttering and slowdown. If I play the same file on Kodi running on my PC I don’t get this issue. Is there a way to solve this problem without disabling hardware acceleration?
Does this happen on all clips or just one or two? There were reports of this issue with a couple of clips, but they seem to be 10-bit or HDR clips. There will be a solution for this shortly
Just updated to the June update and the issue seems to be fixed now!
Started this topic before checking my mail and reading the newsletter about the June update
