Hi There,
Im using RC4 at the moment,
when i go to System -> Settings -> Videos -> Library -> Flatten Library Hierarchy
so first time when i enabled it it was working, but then when i disabled it, it didnt disable the option, when i open movies from homescreen it goes directly to the Title screen, where this option should only work when its enabled.
Can anyone confirm this? You might wanne make a backup before trying…
