I’m using OSMC on Raspberry Pi 3 with Emby add-on.
On Emby I have some home movies and some photos. The Movies and TV shows appear directly in the Movies and TV Menus for OSMC but to view home movies and photos I always have to go to add-ons, Emby, pick the folder and so on.
Is there a way to make these appear in the main menu as with TV and Movies?
TIA.
For queries about addons you are much better served by the Kodi forum Kodi Community Forum - Add-on Support or by contacting the add-on developer directly.
Not 100% sure if I get you right, but if you are using OSMC skin take a look at
Settings>Interface>Skin>Configure Skin>Home>Customize Home menu
You’ve exactly got what I’m after.
I’m not using the OSMC skin but that gave me a clue where to look. I’ve removed a couple of items I don’t need, ‘Music Videos’ and ‘TV’ but I haven’t worked out how to add new items to the main menu.
I’ve loaded a ‘Library Node Editor’ which looks like it just might have what I need but the method isn’t obvious to me - yet.
Thanks.
