It would be good to see some logs so we can advise.
Did you try and restore a backup from the newer version of Kodi or did you take a backup on the older version? Your issues could be caused by restoring an incompatible backup.
The update from November to August included major version change of Kodi which also uses different database structures. For that the database is replicated during the upgrade process to a new version. So restoring a backup after the upgrade would not influence the running database.
Anyway upload debug logs as they would be the only thing that may bring some light to the problem.
reproduce the issue
