Hello,
The power plug of my Vero 4k+ (purchased in May 2021) no longer works.
I replaced it with power plug from a second Vero 4K+ and Vero 4K+ boots normally.
What is the duration of the warranty?
Thanks for the response.
Hello,
See faqs Vero - OSMC.
You can buy a replacement in the OSMC shop, see
UK (product is out of stock)
EU
US
AUS/NZ
Required specification: DC 5V, min. 2A, center positive, coaxial power connector male with OD 5.5mm and ID 2.1mm
Do not use a charger as a replacement for the original power supply, as these often do not have a stable voltage.
