Hi all,
This post is more a FYI than anything else, but last Friday, I started the installation of the last OSMC update while I was eating, then suddenly, I heard a bang.
Go back to my tv to find the Vero 4K being off.
I tried to take off power, then put it back, nothing, it won’t start.
Then, I remove the power supply to smell burnt components, I knew it was dead.
I opened the power supply to find this :
The power supply was 5 years old, but I do not keep it running 24/7, only when I turn on the TV, then shut off the Vero and cut the power from the socket.
I already purchased a replacement on the OSMC store (found the link in another post), so I’m waiting for it.
I just hope that the Vero itself is not burnt as well ![]()
