Evening All,
Just curious, Is it possible to pre-configure the WiFi Settings from outside of code?
For example, when using Ubuntu or Raspbian OS you can configure a wpa-config file and pre-stage the details.
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
network={
ssid="change_me"
psk="change_me"
key_mgmt=WPA-PSK
If this isn’t already possible, would it be in the future?
Simon
