I currently am experimenting with a T95Z Pro S912 box with 2/16GB. I have a file that’s 71.4 GB, a video stream bitrate of 77.9Mb/s and a audio stream bitrate of 4,603kb/s. It’s an HEVC mkv file.
The file just will not play. At first, I thought it was an issue because the gigabit LAN in the box was pretty shitty. But I tried to play it from a HDD as well as through a USB to Gigabit LAN adapter and the video kept freezing, stuttering, and stopping.
Is this something the Vero4K+ would be able to play either through network or through an external HDD?
Well first you need to provide mediainfo of the file as the bitrate alone doesn’t say anything.
And reading through the forum will tell you that sofar most files where able to be played on the Vero4k unless they had encoding issues or where Anime
Do you have a small link to a sample that I can check?
Sorry, I’m new to all of this, trying to figure it out as I go along. Is this what you were talking about?
> Format : HEVC
> Format/Info : High Efficiency Video Coding
> Commercial name : HDR10
> Format profile : Main 10@L5.1@High
> Codec ID : V_MPEGH/ISO/HEVC
> Duration : 2 h 2 min
> Bit rate : 77.9 Mb/s
> Width : 3 840 pixels
> Height : 2 160 pixels
> Display aspect ratio : 16:9
> Frame rate mode : Constant
> Frame rate : 23.976 (24000/1001) FPS
> Color space : YUV
> Chroma subsampling : 4:2:0 (Type 2)
> Bit depth : 10 bits
> Bits/(Pixel*Frame) : 0.392
> Stream size : 66.6 GiB (93%)
> Writing library : ATEME Titan File 3.7.9 (4.7.9.0)
> Default : Yes
> Forced : No
> Color range : Limited
> Color primaries : BT.2020
> Transfer characteristics : PQ
> Matrix coefficients : BT.2020 non-constant
> Mastering display color primaries : Display P3
> Mastering display luminance : min: 0.0000 cd/m2, max: 1000 cd/m2
> Maximum Content Light Level : 1000 cd/m2
> Maximum Frame-Average Light Level : 510 cd/m2
> Audio #1
> Format : MLP FBA 16-ch
> Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
> Commercial name : Dolby TrueHD with Dolby Atmos
> Codec ID : A_TRUEHD
> Bit rate mode : Variable
> Bit rate : 4 603 kb/s
> Maximum bit rate : 7 806 kb/s
> Channel(s) : 8 channels
> Channel layout : L R C LFE Ls Rs Lb Rb
> Sampling rate : 48.0 kHz
> Frame rate : 1 200.000 FPS (40 SPF)
> Compression mode : Lossless
> Delay relative to video : -1 ms
> Stream size : 3.93 GiB (6%)
> Title : TrueHD Atmos 7.1
> Language : English
> Default : Yes
> Forced : No
> Number of dynamic objects : 15
> Bed channel count : 1 channel
> Bed channel configuration : LFE
Can’t see why that video would be an issue on 4K +
