I am installing OSMC on a RPi 3 B+, from a Linux (Fedora 31) machine.
Entering WiFi connection setting post-install on the RPi is tedious (or I’m just quite lazy), so I would like to burn the image with network settings preconfigured — so I insert the SD card, fire the RPi, and can directly ssh to it to finish the install.
The wiki says that pre-configuring network can be done using the OSMC installer. However the installer has gone missing for Linux, and burning the image should be done via dd
Question: How to pre-configure WiFi settings when the image is burn from Linux?
Thank you!
For the record (and because the accepted answer in the link can be misleading) here is what I did (and was successful):
Create a preseed.cfg file as follows (and replace YOUR_WIFI_NAME and YOUR_WIFI_PWD by your actual SSID and password):
d-i target/storage string sd
d-i network/interface string wlan
d-i network/auto boolean true
d-i network/ssid string YOUR_WIFI_NAME
d-i network/wlan_keytype string 1
d-i network/wlan_key string YOUR_WIFI_PWD
Burn the image with your network connection pre-configured:
Insert you SD card, and retrieve its location via lsblk -p.
(The disk — i.e. SD card — location should be something like sdb, or sdc, not followed by a digit. Then replace sdX with this value in the script below.)
Run the following commands (as root):
# Burn the image on SD card (use the relevant path after `if=`)
dd bs=1M if=OSMC_TGT_rbp2_20200402.img of=/dev/sdX conv=fsync
# Mount SD card
mkdir /mnt/osmc
mount /dev/sdX1 /mnt/osmc
# Copy config
cp preseed.cfg /mnt/osmc
# Unmount partition and clean mounting point
umount /dev/sdX1
rm -r /mnt/osmc
Insert the SD card in the RPi, power it up, and… that’s it!
That step should be not necessary as the dd will overwrite the whole card
As sda always is the first disk (normally the one that has your OS) this is quite unlikely the SD Card to be sda unless a very special setup.
Thanks for the hint about dd.
(Regarding sda, I’ve listed here because it’s my case as my disk connected via NVMe port, rather than SATA — but I’ll remove it as it can be misleading indeed.)
Anyway, assuming that the preseed.cfg has been created, I’ve created the following script that can be called as follows:
# ./burn_osmc <disk> <path/to/img> <path/to/cfg>
For example:
./burn_osmc sdb ~/downloads/OSMC_TGT_rbp2_20200402.img ~/sandbox/preseed.cfg
burn_osmc:
# Retrieve arguments
disk_name=$1
img_path=$2
config_path=${3:-preseed.cfg}
dd bs=1M if=$img_path of=/dev/$disk_name conv=fsync
# Mount SD card
mkdir /mnt/osmc
mount /dev/${disk_name}1 /mnt/osmc
# Copy config
cp $config_path /mnt/osmc
umount /dev/${disk_name}1
rm -r /mnt/osmc
