I have an old pi1 running a multiboot system with Raspbmc and Raspbian. (Raspbian on the SD, Raspbmc on a usb stick).
Fdisk shows:
root@raspberrypi:~# fdisk -l
Disk /dev/mmcblk0: 7948 MB, 7948206080 bytes
4 heads, 16 sectors/track, 242560 cylinders, total 15523840 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000a95e6
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 8192 1675781 833795 e W95 FAT16 (LBA)
/dev/mmcblk0p2 1679360 15458303 6889472 85 Linux extended
/dev/mmcblk0p3 15458304 15523839 32768 83 Linux
/dev/mmcblk0p5 1687552 1810431 61440 c W95 FAT32 (LBA)
/dev/mmcblk0p6 1818624 9777151 3979264 83 Linux
/dev/mmcblk0p7 9781248 9945087 81920 c W95 FAT32 (LBA)
/dev/mmcblk0p8 9953280 15454207 2750464 83 Linux
Disk /dev/sda: 7862 MB, 7862353920 bytes
255 heads, 63 sectors/track, 955 cylinders, total 15356160 sectors
Disk identifier: 0x014dc744
/dev/sda1 * 2048 15356159 7677056 b W95 FAT32
Now…i want to get rid of the raspbmc setup and install osmc on it instead…but i do want to keep the Raspbian setup, because it has a touch screen bootloader setup and i dont really want to reinstall the whole thing again.
How should i approach this ? I used NOOBS to install the multiboot (obviously).
Right now i am switching partitions using this script here:
-Thanks
