With my 4K on order, I thought I would ask for recommendations on what is the best way of preparing movies for playback given my set-up?
Currently I backup my Blu-rays as MKVs using MakeMkv. This are then stored on my ReadyNAS and played back via Plex to my LG 4K screen.
Plex will be replaced by the Vero 4K so I will be looking to playback from the ReadNAS over Ethernet to the Vero.
Will the straight MKV copy playback Ok on the Vero, or should I use Handbrake to encode the MKV to a different format, etc. for playback? I am looking for the best quality and smoothest playback (to a 65" 4K TV).
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2 h 12 min
Bit rate mode : Variable
Bit rate : 21.9 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.441
Stream size : 20.3 GiB (87%)
Language : English
Default : No
Forced : No
