Prevent resolv.conf being overwritten
Have Openvpn installed. Getting DNS leaks so had to update my ovpn files with
script-security 2
up /etc/openvpn/update-resolv-conf
down /etc/openvpn/update-resolv-conf
After running openvpn get message
/etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
I used
sudo apt-get install resolv.conf
and it works vpn dns correctly in resolv.conf.
resolv.conf getting overwritten after awhile with
/var/run/connman/resolv.conf
Is there way to keep resolv.conf with symlink of
I can keep backup of original if needed to change.
Or is there a better way of doing this.
You’re not the first with this problem.
Suggest you search for “resolv.conf vpn” in the search box at the top
You may wish to read this, it seems a fix might be on the way.
Yeah I’m on staging repo. This is fixed now resolv.conf doesn’t get overwriteen on reboot anymore
Thanks for confirming this @the_bo
