Problem after irrecord. RPi shut down when i use remote
Hello
I manager to record My AC.Ryan remote with irrecord and Put it in both etc/lirc and home/Osmc/.kodi/ user.
But after when i run lirc and press Any button on the remote My RPi shut down.
This is My recorded lirc file.
Please make this file available to others
by sending it to lirc@bartelmus.de
this config file was automatically generated
using lirc-0.9.0(default) on Wed Oct 17 18:41:57 2018
contributed by
brand: /home/osmc/ac-ryan-playonhd-pv73500-lircd.conf.conf
model no. of remote control:
devices being controlled by this remote:
begin remote
name /home/osmc/ac-ryan-playonhd-pv73500-lircd.conf.conf
flags RAW_CODES|CONST_LENGTH
eps 30
aeps 100
gap 107947
  begin raw_codes
      name KEY_POWER
         9032    2217     602
      name KEY_MUTE
         9018    4466     594     539     597     513
          619     511     594     540     596     512
          621     511     593     539     598     511
          622    1644     596    1644     593    1648
          621    1647     593    1646     613     518
          596     514     620    1643     597    1647
          610    1628     621     511     613    1630
          620    1644     596     513     620    1643
          598     513     619     511     593     540
          597    1644     592     540     597     514
          619    1644     595     514     620    1644
          596
      name KEY_MUTE
          161    6244     271    9832     164
      name KEY_TV
         9047    2197     601
      name KEY_SETUP
         9030    2194     626
      name KEY_INFO
         9052    2191     624
      name KEY_PREVIOUS
         9053    2194     620
      name KEY_NEXT
         9051    2193     616
      name KEY_VOLUMEUP
         9047    2200     597
      name KEY_VOLUMEDOWN
         9059    2188     617
      name KEY_REWIND
         9024    2199     620
      name KEY_FORWARD
         9054    2193     620
      name KEY_UP
         9052    2194     604
      name KEY_DOWN
          152    4953    9064    2185     621
      name KEY_LEFT
         9032    2192     626
      name KEY_RIGHT
         9051    2194     604
      name KEY_ENTER
         9050    2194     567
      name KEY_MENU
         8989    4497     564     568     565     544
          583     550     537     595     563     548
          557     574     563     568     564     545
          585    1657     585    1679     564    1680
          582    1670     599    1654     564     566
          563     545     588    1657     585     546
          584    1663     581    1676     565     579
          553    1681     562     565     566     555
          548     572     563    1678     561     574
          560     570     565    1675     565     569
          562    1679     561    1684     557    1682
          585
      name KEY_EDIT
         9057    2188     623
      name KEY_SELECT
         9056    2192     602
      name KEY_OK
         9047    2200     603
      name KEY_ZOOM
         9111    1616     164     222     694    7325
          158    4040     107
      name KEY_GOTO
         9031    2194     626
      name KEY_SUBTITLE
         9031    2196     621
      name KEY_AUDIO
         9044    2195     568
  end raw_codes
end remote
Remove the entry for KEY_POWER
