I already posted before, but you did not understand or I was not accurate.
I have problems with the icon, Info, Warning and Error. It does not appear. I have this icon, DefaultFile.png, only.
Thanks !
Thanks !
Nobody ?
I can only find one thread of yours here, and this doesn’t mention the icon.
is it in another thread?
Derek
Why send me to this position ? I do not understand.
Please, nobody ?
Perhaps nobody else has the same problem as you, or if they do have the same problem they haven’t noticed, or it doesn’t bother them enough to report it ?
Have you checked the Kodi forums over at http://forum.kodi.tv ? This is almost certainly a generic Kodi issue not something specific to OSMC, so you may get more responses there.
I have not solved my problem !
Did you seek resolution from Kodi forums?
Yes, but I have no more response.
