Since the update 15.1. I have a problem with the icon notifications, They no longer appear
Many Thanks !
Many Thanks !
Nobody ?
Please nobody can help me ?
Sorry, but you’ll find you won’t get much help using a banned addon.
Why is it forbidden ? My question concerns the info icons, not this addon.
It makes me that everywhere
Icons for notifications are provided by the addon when they call the Kodi Notification function. If the icon is no longer appearing it is a bug in the addon that only the addon developer can fix.
Most likely the addon has not been updated to stay compatible with newer versions of Kodi. If the addon is indeed a banned addon you will not get any support for it here. Please contact the addon developer for help with their addon.
