I’ve had my unRaid server automounted by my OSMC pi2and it has worked flawlessly for about a year.
This week, none of my media is seen, and the remote volume is not mounted.
I can connect to the server from my Mac using Macfusion via sshfs, so the server seems OK, and I can log into the server from the Pi using vanilla SSH with a public/private key, so that seems OK.
The /etc/fstab on the Pi has this command:
sshfs#root@*****.***:/mnt/user /mnt/tower fuse comment=sshfs,noauto,users,exec,uid=1000,gid=1000,allow_other,reconnect,transform_symlinks,BatchMode=yes 0 0
That used to mount the volume at boot but now doesn’t. Re-issuing the command
sudo mount -a
silenty proceeds but the volume is not mounted.
Mounting manually with this:
sshfs -o allow_other,reconnect,transform_symlinks,BatchMode=yes root@***.***:/ /mnt/tower
works fine.
I haven’t changed my fstab and the lack of errors on mount -a suggest it’s not broken.
I haven’t upgraded the server, but did update the OSMC/Pi recently. I’m out of options other than Fuse might have changed in the last version of OSMC.
Any advice is appreciated
