I have bought a new WD My book 4TB and copied a couple of videos on it. It gets detected by vero 4k, it can play videos but along the way, especially in longer videos the image starts to freeze up/recover(or not) up to a point where the whole system freezes with a blue, green or black screen and has to be restarted in order to continue to view the selected video. The problem seems to be bigger on higher resolution files but it happens on every format. The file format of the drive is exFat, I left it default. Any tips how can I work around this problem? Or maybe there is a problem with the system?
reproduce the issue
Hello thanks for the detailed explanation. I have enabled debugging, restarted 2 times, opened a video file that played for aprox 3 minutes until the first image freeze. That problem would repeat more and more until the image would be frozen of a certain color(blue green etc). After the first freeze I have uploaded the debug info and got the following link:
