Problem to Connect Bluetooth Earphone
Is it possible to connect my Bluetooth headset to the OSMC?
I tried to use the BT connection but not connect to the headset
Did you install the A2DP package?
No.
Can you tell me how to do this?
https://discourse.osmc.tv/search?q=a2dp
Ok.
Thanks for the help .
I´m make a test and post the results.
Hello.
Thank´s for the help.
i´m made the testes and work perfectly. Afer install A2DB package
Thank´s again
Can you post the make and model of your headset so the team knows what works, please?
