Hi All!
im using 3 raspberry pi v2 mobel b with osmc. hard wired to lan.
it’s play almost everyting ( multiple MKV or Blue Ray iso over 50go!! hosted on a server on the lan) seriously for a tiny board it’s pretty insane!
but some (rare) MKV files was laggy.
what i do:
1- start the playback, (start like every other file, no glitch ou special anything)
2- sound was OK as usual ( no glitch or lag)
3- get the video/picture, but it’s like some frame is discarded. audio and video still in total Sync! instead of having 30fps it’s like having 15 but perfectly in sync. like every X ms they drop a frame.
is a not supported codec? or need to much power to render?
i can upload somewhere the entiere file if needed, something like mega will do the job!
MediaInfo text of this MKV file:
http://paste.osmc.io/fibubiqihi.vhdl
Thanks alot for your help
Do you get the same issue, if you play the laggy mkvs locally on a usb stick?
Thanks Tom.
Thanks Tom for your Fast help!
so, you get’s a simple but logical idea
i juste copied the file to a 500go 3.5 hdd ( powered by it’s own 12v psu)
still get the exactly frame lag / drop. samething like lan playback.
BUT, i see something, i let the movie play and i see the CPU Usage CPU0 : 100% but CPU1-3 was not over 10-12%Max…
it’s possible that the rendering was juste on 1 core and this cause lag / frame drop?
Thanks again Tom!
Have you enabled the VC-1 licence on the Pi? This will enable the Pi to decode VC-1 video in hardware.
What are your hardware accelerations options set to?
Thanks Tom.
As @dillthedog wrote to play a HD VC-1 file you need to purchase the VC-1 codex from Pi foundation
Use Pavtube Video Converter Ultimate (or other video converter) transcode file to h.264 mp4 for Raspberry Pi Smoothly playback via USB.
ooo thanks!
i juste have 1 or 2 vc-1 media so i will convert it to h.264 thanks
