After last update plugin enigma2 / Vu+ PVR record doesn’t start unknown error
This is the log
http://paste.osmc.tv/epagomuhif
This is the log
HI,
17:29:36.111 T:1958539264 ERROR: ADDON: Dll VU+ / Enigma2 Client - Client returned bad status (1) from Create and is not usable
17:29:40.707 T:1958539264 ERROR: UpdateAddons - failed to create add-on VU+ / Enigma2 Client, status = 1
17:29:54.914 T:1958539264 NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - VU+ Addon Configuration options
17:29:54.914 T:1958539264 NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - Hostname: '192.168.1.2'
17:29:54.914 T:1958539264 NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - WebPort: '80'
17:29:54.915 T:1958539264 NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - StreamPort: '8001'
17:29:54.915 T:1958539264 NOTICE: AddOnLog: VU+ / Enigma2 Client: Open Use HTTPS: 'false'
17:29:58.029 T:1958539264 ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
17:29:58.029 T:1958539264 ERROR: CCurlFile::Open failed with code 0 for http://192.168.1.2:80/web/deviceinfo
17:29:58.029 T:1958539264 ERROR: Open - failed to open source <http://192.168.1.2:80/web/deviceinfo>
17:29:58.029 T:1958539264 ERROR: AddOnLog: VU+ / Enigma2 Client: Open It seem's that the webinterface cannot be reached. Make sure that you set the correct configuration options in the addon settings!
I’d double check the addon settings. If they are correct, I would try reseting back to defaults and reconfiguring.
Also if 192.168.1.2 is the server, is there a firewall on the device that may be blocking the clients connection.
Thanks Tom.
my vu+ has blocked any request from http I don’t know why after reboot my vu+
plugin work now very well
Thank you
Glad to hear its sorted.
Tom.
