Problem with ftp connection
Hello.
I have a vero4k + and I have an online seedbox to which I connect in ftp but I have recurring connection problems here is part of the log
ftp://USERNAME:PASSWORD@???:21/ 2019-12-28 22:07:14.963 T:29082 DEBUG: ------ Window Init (DialogBusy.xml) ------ 2019-12-28 22:07:15.218 T:29300 ERROR: CCurlFile::FillBuffer - Failed: FTP: unknown PASV reply(13)
when i try to access in my seedbox, kodi shows me the message ( couldn’t connect to network server )
I can not find any solution the only thing I can say is that I connect to my seedbox with my android smartphone with solid explorer in ftp is it does not work but when i changed settings of solid explorer when I activate the option ftp active mode its works
I do not know if I am very clear in my explanations
sorry for my bad english i’m french
thank you very mush for help
I suspect it may be the same issue discussed here:
If not please provide logs:
  • reboot the OSMC device
  • upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Ok i will inquire with the link you sent me otherwise i will come back here and when the problem recurs i will provide my log
thanks for help
