i know there are multiple threads about this, but i can’t find a solution in it.
So, my hyperion won’t work with OSMC and my PI 2 (with my old PI B and OSMC it works fine)
dtparam=spi=on is in my config.txt and the /dev/spidev0.0 exists.
i tried with a clean installtion, nothing changed
i tried hyperion with the startup as root and as osmc user
everthing i read is about a spi bcm2708 module, but where can i get it? it looks like my system is missing it.
I am using LPD8806 on the GPIO Pins. With my PI B and OSMC, hyperion and the same hyperion.config.json it works fine too. only with the PI2 it doesn’t work
so, its not a problem that i don’t have a spi-bcm2708.ko ?
could it be a problem that i have wiringpi installed and use gpio 02, 03 and 04 for a relay switch
or
could it be a problem that the LED Stripe gets its power after boot?
doesnt necessarily mean that its broken alot of users has experienced issues with hyperion lately could be bugs in the software if you look in the forum you will find alot of threads regarding hyperion.
could do a last ditch effort and go to the hyperion github tracker and report your issue.
