I would say I started to notice problems after on of the last updates.
Some videos won’t play, instead I get rotating animation and sound… No video:
Sometimes I get to sad face…
Example of file:
mediainfo:
https://paste.osmc.tv/dihijavayu.mel
logs: (debugging was on):
https://paste.osmc.tv/sikinukupa.xml
https://paste.osmc.tv/elemexihuz.xml
tnx for any help provided.
Could be a bad rip or a system issue. I notice you have a lot of customisations your device like AppArmor enabled. This might be causing problems with hardware video acceleration.
Iv’e started fresh after a long time… And it got me again at the sad face…
AppArmor will break playback. Why have you enabled it?
Missunderstanding. I’ve started fresh, meaning, I’ve downloaded new image and performed a fresh install without any other stuff…
So, no apparmor. It was installed, because I was hosting homeassistant.
Latest logs:
https://paste.osmc.tv/ecalubujim
Mediainfo for other movie: https://paste.osmc.tv/exeqonapod.vhdl
So, If I disable HW acceleration, it works:
Try on a fresh install without all of these modifications
Hey, as you can see in my previous post, i’ve done that. Fresh install, without modifications, as is…
Now, when I disable hw accel, it works. Otherwise I get a sad face.
Looks like a scaling issue with some files. I’m pretty sure we have vc4_place: Don't reject fractional source coords · popcornmix/linux@ab3ef7a · GitHub included though…
