Problem with Vero 4K+
Hello
I am a happy user of Vero 4k+. Lately, I am having continous problems with playback of media.
The same media worked flawsesly months ago, but now Kodi es falling 2-3 times per hour since 2 weeks.
The playback just stops, randomly (not always in the same place) and media list is shown after the failure. If I continue watching the show, may continue or not, no pattern detected. Sometimes works without problem for 1 hour, other times fails 4-5 times in just 10 minutes.
The relevant log of kodi.log is this:
ERROR : Got MSGQ_ABORT or MSGO_IS_ERROR return true
Full logs available at https://paste.osmc.tv/xaqahupuse
This is my full setup:
Vero 4k+ <— NFS 4.2, wired gigabit ethernet full duplex → Raspberry Pi4 8 GB ram as nfs server <—> USB disk XFS
I have tested this:
  • iperf3 from vero 4k to raspberry pi4, in each direction. 985 Mbs bandwith, no packet loss
  • Vero 4k+ temperature: never over 63 celsius
  • Vero 4k+ fully outdated, regular channel
  • Raspberry Pi4 with Ubuntu 21.10, fully updated
What additional info may I provide to help troubleshoot this issue?
Regards
  1. Suggest to remove this, default configuration is already optimized
<network>
<buffermode> 1 </buffermode>
<readbufferfactor> 1.5 </readbufferfactor>
<cachemembuffersize> 104857600 </cachemembuffersize>
</network>
  1. Suggest to use the x-systemd.automount as described here
    Configuring fstab based NFS share mounts
Thank you for your support fzinken.
I have removed the config and changed fstab to use x-systemd.automount .
Still, this did not solve the original problem, but at least now I am using standard setting and automatic NFS mount.
Next step is to enable debug logging to find more issues
Hello.
I have followed your guidance, enabled debug logs, rebooted twice and I was able to reproduce the issue
2021-11-01 20:16:04.155 T:3145 ERROR : Got MSGQ_ABORT or MSGO_IS_ERROR return true
Logs available at https://paste.osmc.tv/alorehaniw
If you need any aditional info, let me know, I will follow your guidance to troubleshoot this issue.
Again, million of thanks for your support. You are great.
Regards
Well before that you have
2021-11-01 20:16:02.494 T:2667    DEBUG <general>: ActiveAE::SyncStream - average error of 26.343679, start adjusting
2021-11-01 20:16:02.494 T:2667    DEBUG <general>: ActiveAE::SyncStream - average error 0.343679 below threshold of 30.000000
2021-11-01 20:16:02.534 T:3145    DEBUG <general>: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(-205504.354580)
2021-11-01 20:16:02.570 T:3142    DEBUG <general>: CVideoPlayer::HandleMessages - player started 2
2021-11-01 20:16:02.834 T:3145    DEBUG <general>: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(-4879.187580)
2021-11-01 20:16:03.171 T:3142     INFO <general>: Process - eof reading from demuxer
So I think it would be interesting to see if you can replicate the issue when playing the file from a USB stick.
I have bought a usb hub, with its own power cord, and I have connected the 4 TB disk directly to Vero 4k+. I will try to reproduce the issue with this new setup.
Regards
