Hi.
I used and checked the test pattern and found problems with Vero V deinterlacing quality and pulldown detection and handling.
I played back the image with HW decoding and took it. The Vero V has jagged lines. This indicates poor deinterlacing quality. On Android TV Kodi and CoreElec using Amlogic SOC, the lines are not very jagged.
Pull-down detection and processing images are square boxes with no lines and filled in. This indicates that the operation is failing. Kodi and CoreElec on Android TV handle it correctly, so the lines are clearly visible.
The test pattern in the image is from the HQV Benchmark 2.0.
We also ran a similar test with Spears & Munsil HD Benchmark 2nd Edition, and the results were the same.
@tanio99 will know specifics but we had to remove deinterlace from VFM under certain circumstances for performance reasons. Conversely, we can likely reintroduce deinterlacing for certain formats and certain conditions.
Can you provide us with a link to the test pattern you used and we will investigate this further
Here is the link for the test pattern. There are patterns other than the test pattern used in the image. Make use of it. The patterns used in the images are 00005.m2ts and 00006.m2ts.
