Hi Everyone,
I’ve just installed OSMC, having used Raspbmc for a few years. I’m trying to install the no-ip updater software on my Raspberry Pi (I didn’t try this in Raspbmc) but I’m new to linux and i’m getting stuck. I’m new to this forum to but I’m hoping someone can help me out, I’m sure it’s a very basic thing I’m trying to do.
I’m following the instructions at the following link How to Install the Dynamic Update Client on Linux
I get to the command
sudo make
and get the following error.
/home/pi/noip/noip-2.1.9-1$ sudo make
sudo: make: command not found
I’ve read that this error can occur if GCC is not installed, so I tried the following;
sudo apt-get update
sudo apt-get install rbp-userland-dev-osmc (not sure if this was needed)
sudo apt-get install gcc
I’ve rebooted and I’m still getting the same error. If anyone can point me in the right direction it would be a great help.
Many thanks in advance,
Alan
Try installing build-essential - that is usually all that is needed for compiling software on OSMC.
Many thanks for the quick reply.
This resolved my issue. I spent a few hours last night wrestling with this so it’s a relief to be over that particular hurdle… onto the next one. Getting it to run at startup. I’ve done this before in the distance past so this shouldn’t be too much trouble.
Thanks again
I know the discusion is from 2015…but…i can’t make no-ip to install on my pizero…
obvioussly make does not work and i try sudo apt-get install build-essential, but i get
Extracting templates from packages: 100%
Preconfiguring packages …
(Reading database … 26919 files and directories currently installed.)
Preparing to unpack …/libc6_2.28-110.4_armhf.deb …
Unpacking libc6:armhf (2.28-110.4) over (2.28-10+rpi1) …
dpkg: warning: old libc6:armhf package post-removal script subprocess was killed by signal (Segmentation fault)
dpkg: trying script from the new package instead …
dpkg: error processing archive /var/cache/apt/archives/libc6_2.28-110.4_armhf.deb (–unpack):
new libc6:armhf package post-removal script subprocess was killed by signal (Segmentation fault)
dpkg: error while cleaning up:
installed libc6:armhf package pre-installation script subprocess was killed by signal (Segmentation fault)
I suggest creating a new post with logs:-
reproduce the issue
upload the log set (all configs and logs!) either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Have you run sudo apt-get update recently?
