Problems playing movies from NAS
Hey Guys,
I have heavy problems playing any videos with my vero4k+. A while ago everything worked Well but at some point it stopped working. I already made a fresh Install but it didnt Help. Any ideas?
I didnt Change anything in my Network Setup and some Videos still work. some Just Play for a few Seconds and then they Stop
http://paste.osmc.tv/pafuqaqoya
Tanks
First thing I would check is the network performance, details can found here:
Could you please provide the results of the tests in the link.
Also you may want to consider trying with kernel mounts rather than kodi soft mounts:
Thanks Tom.
Hey,
Thanks For the quick reply. Network Speed should be okay. The Vero is wired to a Network Switch, Like the Nas.
I will try mounting the nas a different way, but this does not explain why it suddenly stopped working.
Still would be a good idea to test, being as it was something which was working ok; then started to fail. Could be failing network cable or switch port.
Thanks Tom.
We don’t know what NAS you’re using but have you tried to enable setting at
Settings → Services → SMBclient → Mitigate MTU issues with SMBv2
I am using a Synology 918+ NAS.
I added the shares via autofs now and it seems to be working fine now.
It seems that this fixed the issue.
Thanks!!!
