Problems playing UHD ISO via NAS
Hello,
i have a problem with playing UHD.ISO files.
At first I thought that they wouldn’t play at all, but that’s not the case.
If I have the UHD.ISO on a USB stick on the Vero 4K+ it will play without problems.
If I want to play the same UHD.ISO from my NAS, it simply won’t open.
The m2ts file on the ISO will be played on the NAS without any problems.
OSMC/Kodi seems to have a general problem here if I want to play a UHD.ISO on the network, because it is exactly the same with the Windows version.
Only if it is from the local memory like a USB storage you can…
Does anyone know why this is so?
It is the same filem…
PS: Sorry for my english… i use deepl
Hi, I got my Vero 4K+ yesterday.
After the setup I tried something and a few things make me sad.
I would like to play UHD movies as .iso.
On my Windows PC this works without problems, but unfortunately not on the Vero 4K+.
Is there a solution?
I also have a movie image as .mkv which is in resolution 3840x16xx.
On my Windows PC this is played without problems.
The Vero 4K+ makes image errors in the lower black area.
Many greetings
PS: Sorry for my English… i use deepl…
Translated with DeepL Translate: The world's most accurate translator
Hi MEKak, I merged your double posts to this new topic.
  • reboot the OSMC device
  • upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Is the ISO encrypted?
The logs will help
thank für your help.
Here is my Log:
https://paste.osmc.tv/ogefobaqej
i think the ISO is encrypted…
Did you rip the ISO yourself?
No, I didn’t…
I don’t think that’s the problem either, because the same ISO is played by a USB stick…
Many greetings
I see that you are using UPNP. Could you try configuring the NAS to use NFS and try accessing the ISO that way? UPNP is a FUSE (userspace) driver and will not give you the same performance as an NFS mount will.
Jes, i use UPNP.
i can try it.
This is a good idea.
I’ll write later on how it worked.
EDIT:
I have no idea how to configure NFS.
I did it in my Synology but OSMC doesn’t find any files in the folder …
Did you follow these instructions precisely?
https://kodi.wiki/view/NFS#Synology
i have tried it all the time now and had a thinking error with the NFS setup…
It can’t work if you enter the wrong IP address :slight_smile:
Now I have access to the NAS via NFS and now the UHD.ISO are also played.
It was actually UPNP…
Many thanks for the quick help !!!
