Was this ever resolved in any way? I have the same issue on a Vero4k(non+). I am trying to play Babylon Berlin S02E01 from German public television. I don’t know if this works outside Germany, but it can be legally downloaded
here
Some media info:
$ ffprobe Babylon_Berlin_S02E01.mp4
ffprobe version 4.2.4-1ubuntu0.1 Copyright (c) 2007-2020 the FFmpeg developers
built with gcc 9 (Ubuntu 9.3.0-10ubuntu2)
configuration: --prefix=/usr --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 31.100 / 56. 31.100
libavcodec 58. 54.100 / 58. 54.100
libavformat 58. 29.100 / 58. 29.100
libavdevice 58. 8.100 / 58. 8.100
libavfilter 7. 57.100 / 7. 57.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 5.100 / 5. 5.100
libswresample 3. 5.100 / 3. 5.100
libpostproc 55. 5.100 / 55. 5.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Babylon_Berlin_S02E01.mp4':
Metadata:
major_brand : mp42
minor_version : 0
compatible_brands: isom
creation_time : 2021-10-19T14:55:43.000000Z
encoder : Capella Systems Cambria 4.5.0.51460
encoder-eng : Capella Systems Cambria 4.5.0.51460
Duration: 00:44:02.90, start: 0.000000, bitrate: 4960 kb/s
Stream #0:0(deu): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 4828 kb/s, 50 fps, 50 tbr, 50 tbn, 100 tbc (default)
Metadata:
Stream #0:1(deu): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 124 kb/s (default)
Metadata:
The picture is clearly not running smoothly and lags behind audio.
It does not matter how the video is provided, I tried USB stick and Emby-next-gen. Other videos are running just fine, even with higher bit rate.
Simply recoding video and and changing container with
ffmpeg -i Babylon_Berlin_S02E01.mp4 -c:a copy -c:v libx264 -crf 22 Babylon_Berlin_
S02E01.mkv
does not work, the problem persists.
Hardware is a Hisense TV, directly connected via HDMI.
