Problems updating
I have installed a new osmc from disk image on Pi3
Today decided todo some updating.
After runnin sudo apt-get update
sudo apt-get dist-upgrade - ran into the following problems (had to translate some of the text)
 Настраивается пакет rbp2-image-4.4.13-4-osmc (4) …
 Running depmod.
 Examining /etc/kernel/postinst.d.
 run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.13-4-osmc /boot        /vmlinuz-4.4.13-4-osmc
 run-parts: executing /etc/kernel/postinst.d/inform-updater 4.4.13-4-osmc /boot/v        mlinuz-4.4.13-4-osmc
 run-parts: executing /etc/kernel/postinst.d/process-vmlinuz-rbp 4.4.13-4-osmc /b        oot/vmlinuz-4.4.13-4-osmc
 Aborting due to one or more missing device tree overlays.
 run-parts: /etc/kernel/postinst.d/process-vmlinuz-rbp exited with return code 1
 Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/rbp2-image-4.4.13        -4-osmc.postinst line 391.
 dpkg: error on processing package rbp2-image-4.4.13-4-osmc (--configure):
subprocess stopped due to post-installation returned error 2
 dpkg:dependencies do not let install  rbp2-kernel-osmc:
 rbp2-kernel-osmc depends on от rbp2-image-4.4.13-4-osmc, but:
  package rbp2-image-4.4.13-4-osmc not configured.
 dpkg: error on package rbp2-kernel-osmc (--configure):
 dependency problem - leaving uconfigured
 При обработке следующих пакетов произошли ошибки:
 rbp2-kernel-osmc
It’s known, per this post: Rpi3 apt-get dist-upgrade fails (temporary error, fixed with new kernel) - #2 by sam_nazarko
Indeed – please start a new post if you continue to have issues
