I have en external Bluray drive, conected to the Vero through an SATA->USB bridge. When I insert a DVD it shows up as a hard disk, but some DVDs will not play. Ie our old copy of “Planet 51” that is great for testing the surround system, plays, but not, say Maze Runner:
-12-29 17:25:54.094 T:4987 WARNING <general>: could not find codec parameters for /media/THE_MAZE_RUNNER/VIDEO_TS/VIDEO_TS.IFO
2021-12-29 17:25:54.094 T:4987 INFO <general>: GetVideoAspectRatio - Aspect wanted: 3, Scale permissions: 1
2021-12-29 17:25:54.094 T:4987 INFO <general>: Opening stream: 1 source: 512
2021-12-29 17:25:54.095 T:4987 INFO <general>: GetVideoAspectRatio - Aspect wanted: 3, Scale permissions: 1
2021-12-29 17:25:54.095 T:4987 INFO <general>: Opening stream: 0 source: 512
2021-12-29 17:25:54.095 T:4987 INFO <general>: Finding audio codec for: 0
2021-12-29 17:25:54.095 T:4987 ERROR <general>: Unsupported audio codec
2021-12-29 17:25:54.095 T:4987 ERROR <general>: OpenStream - Unable to init overlay codec
2021-12-29 17:25:54.097 T:4987 INFO <general>: VideoPlayer: next stream, wait for old streams to be finished
2021-12-29 17:25:54.097 T:4987 INFO <general>: Creating Demuxer
2021-12-29 17:25:54.097 T:4987 INFO <general>: GetVideoAspectRatio - Aspect wanted: 3, Scale permissions: 1
2021-12-29 17:25:54.097 T:4987 INFO <general>: Skipped 1 duplicate messages..
2021-12-29 17:25:54.097 T:4987 INFO <general>: msg: libdvdnav: Language 'sv' not found, using 'en' instead
2021-12-29 17:25:54.097 T:4987 INFO <general>: msg: en
2021-12-29 17:25:54.123 T:4987 ERROR <general>: Error getting next block: Error reading NAV packet.
2021-12-29 17:25:54.123 T:4987 WARNING <general>: could not find codec parameters for /media/THE_MAZE_RUNNER/VIDEO_TS/VIDEO_TS.IFO
2021-12-29 17:25:54.123 T:4987 INFO <general>: GetVideoAspectRatio - Aspect wanted: 3, Scale permissions: 1
2021-12-29 17:25:54.124 T:4987 INFO <general>: CVideoPlayer::OnExit()
2021-12-29 17:25:54.125 T:4987 INFO <general>: VideoPlayer: eof, waiting for queues to empty
2021-12-29 17:25:54.141 T:2585 INFO <general>: CVideoPlayer::CloseFile()
2021-12-29 17:25:54.210 T:2585 INFO <general>: VideoPlayer: waiting for threads to exit
2021-12-29 17:25:54.210 T:2585 INFO <general>: VideoPlayer: finished waiting
2021-12-29 17:25:54.210 T:2585 INFO <general>: CVideoPlayer::CloseFile()
I realise that I am probably missing a codec, but which one and how do I get it? Or is it encryption?
Can you please post full debug logs?
Is this a Blu-ray or DVD?
They were regular DVDs. I tried with two this time. The first, Maze Runner first errored, but then played, the second one, Sound of Music/West Side Story, did not play at all.
Logs uploaded as: uyaseyameb
Sorry – I need full logs to look at this.
OK? So the log I uploaded was incomplete? If so, then what should I do to get a full log?
reproduce the issue
But that is what I did
Apart from the reboot twice stuff. I then uploaded the log, as I wrote in the preivious mail:
But I will do this again tonight
Guess @sam_nazarko overlooked it as it was not a link to the logs http://paste.osmc.tv/uyaseyameb
As they are still valid you may not need to upload again
Sorry about that, but I can test again when home.
OK. I did exactly as in the instructions. Was not sure whether to select “component specific logging” so I did.
http://paste.osmc.tv/otifisoraw
I did indeed overlook this post.
I see that you are trying to play from a physical disk drive. That seems to be giving some errors:
Jan 11 17:15:04 osmc kernel: UDF-fs: INFO Mounting volume 'THE_MAZE_RUNNER', timestamp 2014/10/24 20:23 (1000)
Jan 11 17:15:04 osmc udisks-glue[2587]: Successfully automounted /dev/sr0 at /media/THE_MAZE_RUNNER
Jan 11 17:15:04 osmc udisks-glue[2587]: Device file /dev/sr0 mounted at /media/THE_MAZE_RUNNER
Jan 11 17:15:11 osmc kernel: sr 0:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Jan 11 17:15:11 osmc kernel: sr 0:0:0:0: [sr0] tag#0 Sense Key : 0x5 [current]
Jan 11 17:15:11 osmc kernel: sr 0:0:0:0: [sr0] tag#0 ASC=0x6f ASCQ=0x3
Jan 11 17:15:11 osmc kernel: sr 0:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 2e 6c e7 00 00 08 00
Jan 11 17:15:11 osmc kernel: blk_update_request: I/O error, dev sr0, sector 12170140
Jan 11 17:15:11 osmc kernel: sr 0:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 2e 6c e7 00 00 02 00
Sometimes this is a region lock issue.
OK. Is there a way around that? Should I try copying the files to disk and play from there?
It would be interesting to know if doing that works at all. I suspect you won’t be able to copy the files or they might appear to copy but be corrupted (as the nature of the DVD protection scheme).
I can certainly try. IIRC was it possible to change/circumvent the region stuff on regular DVD players in the past?
You can change the region a few times usually, but after that, the drive is stuck on that region.
