Hi!
I have copied some 3D blu-rays into images which I play with OSMC. For some 3D blue-ray images I am noticing problems: I can start playing the movies, but whenever I do something (changing the audio track, rewind, pause, etc.), the movie stops playing and OSMC crashes (I have still access to the Pi from the network, but the UI keeps unresponsive) and I need to disconnect power to reboot the Pi. This happens for some movies, only, is fully reproducible and happens in the same way when I use libreELEC (this problem was in fact the reason for me to try OSMC instead of LibreELEC). The Problem does not occur, when I create MKVs from these images with makeMKV.
Movies, for which this happens are for instance Aladdin, Avatar, Blade Runner 2019, The Croods.
reproduce the issue
upload the log set (all configs and logs!) either using the
