My router is 5G, so it broadcasts two bands, standard and 5G. I connected to 5G after the system setup, all was working fine. Then I shut down the device, connected it to TV screen, turned on, all things looked like the connection was still working and yet, got errors during downloads or some streaming plugins. So I connected to my normal network, and it worked, after some time I started getting the same errors, so it looked like the same situation: system is connected to network but has no internet.
So I tried again connecting to 5G network and… can’t. It hangs on “Configuring…” for a few minutes, then it shows that connection failed. I tried many times and got the same results. Since 5G is faster, it’s better for streaming plugins.
So the issue here are:
- problems connecting to 5G network
- loosing internet while still being connected to normal (non 5G) network or often there is no internet from the start, status: wlan0 connected, then after a 10 minutes it changes to connected (internet finally working).
- during changing networks, quite often system either freezes permanently or crashes (blue screen with sad face) and see some error about unhandled exception - how changing wifi networks can crash system? this is absurd
- internet often seems very slow (streaming videos often buffer, reaction time after clicking is incredibly long, just seeing spinner) - it’s unusable, although I have fibre Internet up to 480 MB/s (tested and confirmed, even sometimes above that)
Note: my previous OSMC installation had no such problems, all worked fine. All other devices are connected without problems, so it’s not the issue with router.
Without a normal, stable connection, the whole device becomes useless, so this is a serious issue. I gave up on LibreElec just because it kept forgetting the passwords after the restart, which is also a big deal. Again, in previous OSMC installation all worked fine. Unfortunately, the SD card just died and had to install the system anew. This is frustrating.
EDIT:
I was wondering what has changed and:
- This is the same device (Rasberry Pi3)
- The same place (should have strong signal)
- The same system
- Different SD card… - now I am wondering, maybe this is the root of the problems?
I noticed that this system is freezing regularly for 1-5 seconds. This wasn’t happening on the old card. Can it be that this freeze is also the root of the buffering (system stops downloading for a moment), various delays and maybe the talking between devices (connection)?
