Progress bar for restoring a backup
would be very nice if you could make a progress bar for the restore progress.
It takes about 15-20 minutes to restore the whole system (vero 4k) from a backup when restoring all. and you can’t see any progress.
The only way to check if the device is working, is to check the cpu performace while restoring.
just a please wait or something would be enough but at the moment i don’t know if the restore process is working or not.
thanks
In My OSMC 2.0, we will improve the backup system.
Of course, as a Vero user, when OSMC Cloud launches, you will have automatic backups that occur in the background, so you won’t need to worry about this kind of thing.
Is there any release time frame for this?
Not at this time. It’s low on the list of priorities for now
