I wonder if it’s possible or likely that someone would consider compiling a Project M Visualizer add-on for KODI/OSMC. It seems like something doable, but not with my zero coding/compiling skills…
It’s in the LibreELEC Repository, although I can’t state that for any hardware platform other than x86 generic…
Ok, but I’m not seeing any listed at all. Nothing in the KODI Repository and I don’t see an OSMC Repository. Is that something I have to add as a zip file first or should it be visible in the standard install?
Ok, if you say so…! I’ve searched for them until the buttons fell off my remote. I see lots of installed but disable add-ons, such as languages and PVR clients but I see no visualizations. Could you point me to any documentation or throw out a clue for me to follow?
Save the buttons of your remote, it might be that on a latest build they might have been not included for whatever reason.
Which version of OSMC are you on?
