ok done
18:48:02 T:3025006592 NOTICE: Log level changed to “LOG_LEVEL_DEBUG_FREEMEM”
18:48:02 T:3025006592 NOTICE: Enabled debug logging due to GUI setting. Level 2.
18:48:02 T:3025006592 DEBUG: ------ Window Init () ------
18:48:02 T:2936009760 DEBUG: PushCecKeypress - received key b duration 205 (rep:0 size:0)
18:48:02 T:2936009760 DEBUG: PushCecKeypress - ignored key b
18:48:05 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
18:48:05 T:2936009760 DEBUG: PushCecKeypress - added key a7
18:48:05 T:3025006592 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
18:48:06 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 207 (rep:0 size:0)
18:48:06 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:48:13 T:2936009760 DEBUG: PushCecKeypress - received key d8 duration 0 (rep:0 size:0)
18:48:13 T:2936009760 DEBUG: PushCecKeypress - added key d8
18:48:13 T:3025006592 DEBUG: OnKey: menu (0xd8) pressed, action is PreviousMenu
18:48:13 T:3025006592 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:48:13 T:2936009760 DEBUG: PushCecKeypress - received key d8 duration 75 (rep:0 size:0)
18:48:13 T:2936009760 DEBUG: PushCecKeypress - ignored key d8
18:48:13 T:3025006592 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
18:48:13 T:3025006592 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
18:48:13 T:3025006592 DEBUG: ------ Window Init (Settings.xml) ------
18:48:13 T:2853315616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0xab3ca410
18:48:13 T:2853315616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(402672), nBufferAlignmen(16)
18:48:13 T:2853315616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0xab34fc58
18:48:13 T:2853315616 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
18:48:13 T:2853315616 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0xab3ca410
18:48:13 T:2853315616 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0xab34fc58
18:48:13 T:2853315616 DEBUG: DecodeJpegToTexture: decoded special://skin/backgrounds/settings.jpg 1024x576
18:48:15 T:2936009760 DEBUG: PushCecKeypress - received key d8 duration 0 (rep:0 size:0)
18:48:15 T:2936009760 DEBUG: PushCecKeypress - added key d8
18:48:15 T:3025006592 DEBUG: OnKey: menu (0xd8) pressed, action is PreviousMenu
18:48:15 T:3025006592 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:48:15 T:2936009760 DEBUG: PushCecKeypress - received key d8 duration 205 (rep:0 size:0)
18:48:15 T:2936009760 DEBUG: PushCecKeypress - ignored key d8
18:48:15 T:3025006592 DEBUG: ------ Window Deinit (Settings.xml) ------
18:48:15 T:3025006592 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
18:48:15 T:3025006592 DEBUG: ------ Window Init (Home.xml) ------
18:48:16 T:2936009760 DEBUG: PushCecKeypress - received key a9 duration 0 (rep:0 size:0)
18:48:16 T:2936009760 DEBUG: PushCecKeypress - added key a9
18:48:17 T:3025006592 DEBUG: OnKey: 169 (0xa9) pressed, action is Left
18:48:17 T:2936009760 DEBUG: PushCecKeypress - received key a9 duration 76 (rep:0 size:0)
18:48:17 T:2936009760 DEBUG: PushCecKeypress - ignored key a9
18:48:17 T:2936009760 DEBUG: PushCecKeypress - received key a9 duration 0 (rep:0 size:0)
18:48:17 T:2936009760 DEBUG: PushCecKeypress - added key a9
18:48:17 T:2936009760 DEBUG: PushCecKeypress - received key a9 duration 74 (rep:0 size:0)
18:48:18 T:2936009760 DEBUG: PushCecKeypress - received key a9 duration 0 (rep:0 size:0)
18:48:18 T:2936009760 DEBUG: PushCecKeypress - added key a9
18:48:18 T:3025006592 DEBUG: OnKey: 169 (0xa9) pressed, action is Left
18:48:18 T:2936009760 DEBUG: PushCecKeypress - received key a9 duration 72 (rep:0 size:0)
18:48:18 T:2936009760 DEBUG: PushCecKeypress - ignored key a9
18:48:36 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
18:48:36 T:2936009760 DEBUG: PushCecKeypress - added key a7
18:48:36 T:3025006592 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
18:48:36 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 207 (rep:0 size:0)
18:48:36 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:48:43 T:2853315616 DEBUG: Thread JobWorker 2853315616 terminating (autodelete)
18:48:51 T:2936009760 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
18:48:51 T:2936009760 DEBUG: PushCecKeypress - added key b
18:48:51 T:3025006592 DEBUG: OnKey: 11 (0x0b) pressed, action is Select
18:48:51 T:3025006592 DEBUG: Activating window ID: 10025
18:48:51 T:2936009760 DEBUG: PushCecKeypress - received key b duration 204 (rep:0 size:0)
18:48:51 T:2936009760 DEBUG: PushCecKeypress - ignored key b
18:48:52 T:3025006592 DEBUG: ------ Window Deinit (Home.xml) ------
18:48:52 T:3025006592 DEBUG: ------ Window Init (MyVideoNav.xml) ------
18:48:52 T:3025006592 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
18:48:53 T:3025006592 DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
18:48:53 T:3025006592 DEBUG: ParentPath = [sources://video/]
18:48:53 T:2853315616 NOTICE: Thread BackgroundLoader start, auto delete: false
18:48:53 T:2853315616 DEBUG: Thread BackgroundLoader 2853315616 terminating
18:48:54 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
18:48:54 T:2936009760 DEBUG: PushCecKeypress - added key a7
18:48:54 T:3025006592 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
18:48:54 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 75 (rep:0 size:0)
18:48:54 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:48:55 T:2936009760 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
18:48:55 T:2936009760 DEBUG: PushCecKeypress - added key b
18:48:55 T:3025006592 DEBUG: OnKey: 11 (0x0b) pressed, action is Select
18:48:55 T:3025006592 DEBUG: CGUIMediaWindow::GetDirectory (nfs://192.168.0.50/media/ext4/mlnet/incoming/)
18:48:55 T:3025006592 DEBUG: ParentPath = [sources://video/]
18:48:55 T:2853315616 NOTICE: Thread JobWorker start, auto delete: true
18:48:55 T:2853315616 DEBUG: SECTION:LoadDLL(libnfs.so.4)
18:48:55 T:2853315616 DEBUG: Loading: libnfs.so.4
18:48:55 T:2936009760 DEBUG: PushCecKeypress - received key b duration 205 (rep:0 size:0)
18:48:55 T:2936009760 DEBUG: PushCecKeypress - ignored key b
18:48:55 T:3025006592 DEBUG: ------ Window Init (DialogBusy.xml) ------
18:48:56 T:2853315616 DEBUG: NFS: Context for 192.168.0.50/media/ext4/mlnet/incoming not open - get a new context.
18:48:56 T:2853315616 DEBUG: NFS: Connected to server 192.168.0.50 and export /media/ext4/mlnet/incoming
18:48:56 T:2853315616 DEBUG: NFS: chunks: r/w 65536/65536
18:48:56 T:3025006592 DEBUG: Saving fileitems [nfs://192.168.0.50/media/ext4/mlnet/incoming/]
18:48:56 T:3025006592 DEBUG: – items: 5, sort method: 0, ascending: true
18:48:57 T:3025006592 DEBUG: RunQuery took 7 ms for 0 items query: select * from movieview WHERE c23=3
18:48:57 T:2811372576 NOTICE: Thread BackgroundLoader start, auto delete: false
18:48:57 T:3025006592 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
18:48:57 T:2811372576 DEBUG: Thread BackgroundLoader 2811372576 terminating
18:48:59 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
18:48:59 T:2936009760 DEBUG: PushCecKeypress - added key a7
18:48:59 T:3025006592 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
18:48:59 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 209 (rep:0 size:0)
18:48:59 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:49:00 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 75 (rep:0 size:0)
18:49:00 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:49:00 T:2936009760 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
18:49:00 T:2936009760 DEBUG: PushCecKeypress - added key b
18:49:00 T:3025006592 DEBUG: OnKey: 11 (0x0b) pressed, action is Select
18:49:00 T:3025006592 DEBUG: CGUIMediaWindow::GetDirectory (nfs://192.168.0.50/media/ext4/mlnet/incoming/files/)
18:49:00 T:3025006592 DEBUG: ParentPath = [nfs://192.168.0.50/media/ext4/mlnet/incoming/]
18:49:00 T:2936009760 DEBUG: PushCecKeypress - received key b duration 75 (rep:0 size:0)
18:49:00 T:2936009760 DEBUG: PushCecKeypress - ignored key b
18:49:00 T:3025006592 DEBUG: RunQuery took 44 ms for 16 items query: select * from movieview WHERE c23=4
18:49:00 T:3025006592 DEBUG: RunQuery took 4 ms for 16 items query: SELECT files.strFilename, files.playCount, bookmark.timeInSeconds, bookmark.totalTimeInSeconds FROM files LEFT JOIN bookmark ON files.idFile = bookmark.idFile AND bookmark.type = 1 WHERE files.idPath=4
18:49:00 T:2811372576 NOTICE: Thread BackgroundLoader start, auto delete: false
18:49:02 T:2811372576 DEBUG: Thread BackgroundLoader 2811372576 terminating
18:49:03 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
18:49:03 T:2936009760 DEBUG: PushCecKeypress - added key a7
18:49:03 T:3025006592 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
18:49:03 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 76 (rep:0 size:0)
18:49:03 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:49:04 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
18:49:04 T:2936009760 DEBUG: PushCecKeypress - added key a7
18:49:04 T:3025006592 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
18:49:04 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 75 (rep:0 size:0)
18:49:04 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:49:04 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 409 (rep:0 size:0)
18:49:05 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 71 (rep:0 size:0)
18:49:05 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:49:05 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
18:49:05 T:2936009760 DEBUG: PushCecKeypress - added key a7
18:49:05 T:3025006592 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
18:49:05 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 75 (rep:0 size:0)
18:49:05 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 74 (rep:0 size:0)
18:49:06 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
18:49:06 T:2936009760 DEBUG: PushCecKeypress - added key a7
18:49:06 T:3025006592 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
18:49:06 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 207 (rep:0 size:0)
18:49:06 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:49:06 T:2811372576 NOTICE: Thread JobWorker start, auto delete: true
18:49:06 T:2853315616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0xab3ced90
18:49:06 T:2853315616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(109840), nBufferAlignmen(16)
18:49:06 T:2853315616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0xb3aedf58
18:49:06 T:2853315616 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
18:49:06 T:2811372576 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x44c38b0
18:49:06 T:2853315616 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0xab3ced90
18:49:06 T:2811372576 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(91360), nBufferAlignmen(16)
18:49:06 T:2853315616 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0xb3aedf58
18:49:06 T:2853315616 DEBUG: DecodeJpegToTexture: decoded special://masterprofile/Thumbnails/d/d1757536.jpg 1280x720
18:49:06 T:2811372576 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0x44c34a8
18:49:06 T:2811372576 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
18:49:06 T:2811372576 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0x44c38b0
18:49:06 T:2811372576 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0x44c34a8
18:49:06 T:2811372576 DEBUG: DecodeJpegToTexture: decoded special://masterprofile/Thumbnails/e/ea459d8a.jpg 509x720
18:49:06 T:2811372576 DEBUG: DoWork - took 109 ms to load special://masterprofile/Thumbnails/e/ea459d8a.jpg
18:49:06 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 209 (rep:0 size:0)
18:49:06 T:2853315616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(151520), nBufferAlignmen(16)
18:49:06 T:2853315616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0xab3d06a0
18:49:06 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 75 (rep:0 size:0)
18:49:06 T:2853315616 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0xab3d06a0
18:49:06 T:2853315616 DEBUG: DecodeJpegToTexture: decoded special://masterprofile/Thumbnails/5/575d3181.jpg 1280x720
18:49:07 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
18:49:07 T:2936009760 DEBUG: PushCecKeypress - added key a7
18:49:07 T:3025006592 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
18:49:07 T:2811372576 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x44c2438
18:49:07 T:2811372576 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(260368), nBufferAlignmen(16)
18:49:07 T:2811372576 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0x45134e8
18:49:07 T:2811372576 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
18:49:07 T:2853315616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0xab3ced90
18:49:07 T:2853315616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(111520), nBufferAlignmen(16)
18:49:07 T:2853315616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0xa7006fe0
18:49:07 T:2811372576 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0x44c2438
18:49:07 T:2853315616 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
18:49:07 T:2811372576 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0x45134e8
18:49:07 T:2811372576 DEBUG: DecodeJpegToTexture: decoded special://masterprofile/Thumbnails/f/ff25dc11.jpg 1280x720
18:49:07 T:2811372576 DEBUG: DoWork - took 127 ms to load special://masterprofile/Thumbnails/f/ff25dc11.jpg
18:49:07 T:2853315616 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0xab3ced90
18:49:07 T:2853315616 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0xa7006fe0
18:49:07 T:2853315616 DEBUG: DecodeJpegToTexture: decoded special://masterprofile/Thumbnails/2/2dc10a76.jpg 480x720
18:49:07 T:2853315616 DEBUG: DoWork - took 141 ms to load special://masterprofile/Thumbnails/2/2dc10a76.jpg
18:49:07 T:2936009760 DEBUG: PushCecKeypress - received key a7 duration 212 (rep:0 size:0)
18:49:07 T:2936009760 DEBUG: PushCecKeypress - ignored key a7
18:49:08 T:2936009760 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
18:49:08 T:2936009760 DEBUG: PushCecKeypress - added key b
18:49:08 T:3025006592 DEBUG: OnKey: 11 (0x0b) pressed, action is Select
18:49:08 T:3025006592 DEBUG: OnPlayMedia nfs://192.168.0.50/media/ext4/mlnet/incoming/files/Cars 1 - Motori Ruggenti.avi
18:49:08 T:3025006592 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
18:49:08 T:3025006592 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
18:49:08 T:3025006592 DEBUG: Loading settings for nfs://192.168.0.50/media/ext4/mlnet/incoming/files/Cars 1 - Motori Ruggenti.avi
18:49:08 T:2936009760 DEBUG: PushCecKeypress - received key b duration 205 (rep:0 size:0)
18:49:08 T:2936009760 DEBUG: PushCecKeypress - ignored key b
18:49:08 T:3025006592 DEBUG: CPlayerCoreFactory::GetPlayers(nfs://192.168.0.50/media/ext4/mlnet/incoming/files/Cars 1 - Motori Ruggenti.avi)
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
18:49:08 T:3025006592 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
18:49:08 T:3025006592 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
18:49:08 T:3025006592 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
18:49:08 T:3025006592 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
18:49:08 T:3025006592 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
18:49:08 T:3025006592 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
18:49:08 T:3025006592 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
18:49:09 T:3013604384 DEBUG: CAESinkPi:Drain delay:58ms now:0ms
18:49:09 T:3013604384 DEBUG: CAESinkPi:Deinitialize
18:49:09 T:3013604384 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000000
18:49:09 T:3013604384 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.audio_render handle 0xb3001b38
18:49:09 T:3025006592 NOTICE: DVDPlayer: Opening: nfs://192.168.0.50/media/ext4/mlnet/incoming/files/Cars 1 - Motori Ruggenti.avi
18:49:09 T:3025006592 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:49:09 T:3025006592 DEBUG: CMMALRenderer::CMMALRenderer
18:49:09 T:3025006592 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
18:49:09 T:3025006592 DEBUG: CMMALRenderer::UnInit
18:49:09 T:3025006592 DEBUG: CMMALRenderer::PreInit
18:49:09 T:2799223840 NOTICE: Thread CMMALRenderer start, auto delete: false
18:49:09 T:2870211616 NOTICE: Thread DVDPlayer start, auto delete: false
18:49:09 T:2870211616 NOTICE: Creating InputStream
18:49:09 T:2870211616 DEBUG: CNFSFile::Open - opened media/ext4/mlnet/incoming/files/Cars 1 - Motori Ruggenti.avi
18:49:09 T:2870211616 DEBUG: ScanForExternalSubtitles: Searching for subtitles…
18:49:09 T:2870211616 DEBUG: CNFSFile::Open - opened media/ext4/mlnet/incoming/files/ROMs Neo Geo, Mame, CPS-2-1, N64, Amiga 500, SNES, NES, Genesis, SMS, Atari, Spectrum, GBA, GBC by simian raticus.[sharethefiles.com].rar
18:49:09 T:3025006592 DEBUG: ------ Window Init (DialogBusy.xml) ------
18:49:37 T:2811372576 DEBUG: Thread JobWorker 2811372576 terminating (autodelete)
18:49:37 T:2853315616 DEBUG: Thread JobWorker 2853315616 terminating (autodelete)
18:50:27 T:2882200608 DEBUG: RunQuery took 38 ms for 16 items query: select * from movieview WHERE ((movieview.playCount IS NULL OR movieview.playCount < 1))
18:50:29 T:2882200608 DEBUG: RunQuery took 24 ms for 0 items query: select * from episodeview WHERE ((episodeview.playCount IS NULL OR episodeview.playCount < 1))
18:50:29 T:2882200608 DEBUG: GetSongsByWhere query = SELECT songview.* FROM songview WHERE ((CAST(songview.iTimesPlayed as DECIMAL(5,1)) < 1))
18:50:29 T:2882200608 DEBUG: GetAlbumsByWhere query: SELECT albumview.* FROM albumview WHERE albumview.strAlbum <> ‘’
18:50:29 T:2882200608 DEBUG: GetAlbumsByWhere - query took 8 ms
18:52:08 T:3025006592 DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
18:52:08 T:3025006592 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
18:52:08 T:3025006592 DEBUG: ------ Window Init () ------
