could you please enable # CONFIG_HID_SONY in kernel default config or point me to a tutorial in order to recompile the kernel?
Thank you
Thank you
Not a problem. I’ve done this and pushed this to our staging repository.
To test this update:
echo 'deb http://apt.osmc.tv buster-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
I’d also recommend you deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
Hi Sam,
thank you, the controller is now initialized.
Happy new year.
Thanks for confirming.
