Hello,
I want to install Pyload RPi2 running on Osmc Alpha 4, but I get an error.
I have used this tutorial and starten at 3:
osmc@osmc:~$ sudo apt-get -y install python python-crypto python-pycurl python-qt4 tesseract-ocr tesseract-ocr-eng python-imaging rhino zip unzip
Reading package lists… Done
Building dependency tree
python-crypto is already the newest version.
python-pycurl is already the newest version.
rhino is already the newest version.
tesseract-ocr is already the newest version.
tesseract-ocr-eng is already the newest version.
zip is already the newest version.
unzip is already the newest version.
python-imaging is already the newest version.
python is already the newest version.
python-qt4 : Depends: libqt4-declarative (>= 4:4.8.0-1~) but it is not going to be installed
Depends: libqt4-designer (>= 4:4.8.0-1~) but it is not going to be installed
Depends: libqt4-help (>= 4:4.8.0-1~) but it is not going to be installed
Depends: libqt4-scripttools (>= 4:4.8.0-1~) but it is not going to be installed
Depends: libqt4-svg (>= 4:4.8.0-1~) but it is not going to be installed
Depends: libqtgui4 (>= 4:4.8.0-1~) but it is not going to be installed
Depends: libqtwebkit4 (>= 2.2.0) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Sudo apt-get -f install did not work…
Please help me
