Python 3.10 official way
what is an official way of python 3.10 installation?
Regards.
I assume you want this because of proposed performance benefits
I’d suggest waiting at this time. It is only available in Bookworm.
What is Bookworm?
https://www.debian.org/releases/bookworm/
OSMC is uses debian as the BASEOS.
As sam advised, your best bet is to wait.
Thanks Tom.
Well, I am assessing osmc on rpi4 as development machine.
For that I will need several verions of python (3.8.x, 3.9.x, 3.10.x…) at the same time and ability to use different python version for different project.
I know that debian is quite conservative regarding python.
What is suggested way of installing different versions of python in osmc?
Compiling from source and using the alt install method:
Regards Tom.
Hi, I hoped that I will somehow avoid building from the source (it takes a lot).
Has someone used pyenv (GitHub - pyenv/pyenv: Simple Python version management)?
Regards
Is OSMC team planning to move to higher version of python 3.10.x any time soon?
We ship the version that comes with Debian
