Hello all,
I am struggling to get the IR receiver to work on my new RPi 2 running OSMC RC. I installed it in the same way as my old original Raspberry Pi.
I enabled the option under RPi settings. Selected the correct LIRC remote config under “Remotes” but i still can’t get it to work.
dmesg | grep lirc returns this:
[ 7.733669] lirc_dev: IR Remote Control driver registered, major 246
[ 7.754351] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.710663] lirc_rpi: auto-detected active high receiver on GPIO pin 17
[ 8.711118] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 8.711138] lirc_rpi: driver registered!
[ 9.471707] input: lircd as /devices/virtual/input/input4
What am I doing wrong? Any suggestions as to how I can fix this and get it to work? It worked perfectly under Raspbmc.
Thank you in advance
