Qobuz plugin
is here somebody who can play Qobuz on VeroV ? I would appreciate any guidance.
thanks
The Addon seems not be supported anymore
https://forum.kodi.tv/showthread.php?tid=146568
So I think there is no way for you to use it on the Vero
I’ve got an idea, but I don’t know if it will be possible: use LMS which have support for Qobuz, with squeezebox plugin.
Is somebody running such combination on VeroV?
