Question about autofs setup
I should have assumed that. Ok, ran the prompt then it says the syslog option is depreciated.
Connection to 192.168.1.215 failed (Error NT_STATUS_CONNECTION_REFUSED)
NetBIOS over TCP disabled -- no workgroup available
But it did install and says it’s the latest version.
Ok, your MAC isn’t accepting SMB connections.
Try:
smbclient -L <IP> -m SMB2
or SMB3 or NT1 instead.
WARNING: The “syslog” option is deprecated
Enter osmc’s password:
session setup failed: NT_STATUS_LOGON_FAILURE
All 3 give me that error message
Then you need to look into the MACs setup. It’s not allowing you to connect on a very basic level. Have you setup a osmc user on the MAC for SMB? (I don’t have a MAC, so I have no clue how to properly setup SMB on one).
It’s a shame that Apple doesn’t just allow you to use NFS, which is native to *nix…
So what user have you created on the MAC for SMB and what permission does it have?
I made a guest and my main account. My account is read and write and all other accounts are read only. I can try read and write and see if that helps.
Just for testing try -U MainAccount
Same error
NetBIOS over TCP disabled – no workgroup available
Ok, not sure how the SMB server is configured on MAC and how certain settings are done (e.g. IP range). Are you accessing the MAC successfully from other SMB Clients?
How exactly did you get this working? Was it Kodi mounts?
I just clicked add network connection and selected SMB. It can still connect. I can test a file.
And you didn’t supply a username/password? If so then you are connecting as a guest. You probably need to add a osmc user/password to the MAC SMB config.
I did have to put in the guest user/pass.
And you are using the same user/password with smbclient?
Yep tried both accounts.
Here’s my log file
Https://paste.osmc.tv/hurificuhe
Something isn’t right here. You say you did:
and got:
But when you try:
smbclient -L <IP> -m SMB2 -U <user>
you get:
So now it’s refusing the connection instead of the credentials.
I’ll try again now and see what it says.
osmc@osmc : ~ $ smbclient -L 192.168.1.215 -m SMB2
osmc@osmc : ~ $ smbclient -L 192.168.1.215 -m SMB2 -U Guest1
Enter Guest1’s password:
Edit: Accidentally typed OSMC PW I did it again with the guest pw and here’s what I got
Domain=[JORDANMAC] OS= Server=
Sharename       Type      Comment
4K              Disk
Guest1’s Public Folder Disk
IPC$            IPC
Jordan Schneider’s Public Folder Disk
Kodi            Disk
Movies          Disk
Plex            Disk
Plex1           Disk
Guest1          Disk
Try the other options, SMB3 and NT1.
