Question about autofs setup
Just edited the above post I typed the wrong pw this was the result I got from the second option
Domain=[JORDANMAC] OS= Server=
Sharename       Type      Comment
4K              Disk
Guest1’s Public Folder Disk
IPC$            IPC
Jordan Schneider’s Public Folder Disk
Kodi            Disk
Movies          Disk
Plex            Disk
Plex1           Disk
Guest1          Disk
Connection to 192.168.1.215 failed (Error NT_STATUS_CONNECTION_REFUSED)
NetBIOS over TCP disabled – no workgroup available
What password is in your .credentials file? Make sure the user is Guest1 and the correct password. Restart autofs and try again.
I used the guest password but I’ll check it again
So based on this your original config was wrong with Volumes it should be
://192.168.1.215/Plex1/ instead.
That’s so weird everywhere else on my Mac I have to use volumes before the drive directory. I can’t thank you guys enough. Is there a tip jar lol.
It’s working after that change?
It is.
Totally appreciate that. Just figured if I could help out a little extra I would. Bought the Vero 4K+ months ago and finally hooked it up. Amazing product so far!
