I am looking for a somewhat cheap, yet, easy (if it exists) HTPC for my parents.
I was thinking about a RaspberryPi 3, with OSMC. It would be hooked up to the TV directly via HDMI, with an external drive holding all the media plugged into the Pi via USB.
Most of the media is mkv files, some of them pretty big (high quality, high bitrate) files, and I am wondering if OSMC/Pi could handle it?
My parents currently have an older computer that is hooked to the TV via network, but the TV doesn’t suport many formats, and thus requires the computer to try and transcode everything. The computer can’t handle it, and thus, they are unable to watch most of the media they have.
An example media:
General
Unique ID : 223437692056723884181354198506919775514 (0xA81888C04303A0E894E37E9BE6214D1A)
Complete name : \TV Shows\Band of Brothers\Season 01\Band.of.Brothers.s01e01.Currahee.1080p.BluRay.mkv
Format : Matroska
Format version : Version 2
File size : 11.5 GiB
Duration : 1 h 13 min
Overall bit rate : 22.4 Mb/s
Encoded date : UTC 2011-10-19 19:54:53
Writing application : mkvmerge v5.0.1 (‘Es ist Sommer’) built on Oct 9 2011 11:55:43
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 21.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.422
Stream size : 10.5 GiB (91%)
Title : x264
Writing library : x264 core 118 r2085 8a62835
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=250 / rc=2pass / mbtree=1 / bitrate=21000 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=38000 / vbv_bufsize=30000 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.60
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 spf)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 790 MiB (7%)
Title : DTS 5.1
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Invasion Postponed
00:08:26.256 : en:Anything But Easy
00:23:44.340 : en:Paratrooper Certification
00:33:34.846 : en:Off to England
00:42:35.511 : en:Trial By Court-Martial
00:52:14.882 : en:D-Day Preparations
