So I’ve decided to try OSMC since I wanna use Kodi and opencanary+adguard oin the same RPi4.
Using the EXACT same SDcard that I’ve tried DietPI, Rasbian and LibreELEC on (without any problems) now doesn’t work with OSMC.
I’m gettign stuck at rainbowscreen and can’t get past. i’ve tried several different installallers OSMC, Rufus, Raspian own installer and same problem but only with OSMC. if i switch to another distro it boots and works without problems.
I am clueless.
Anyone got an idea?
Best regards from Norway
