Hey Sam, thank you for the help. Is there any config.gz file on OSMC?
So I did the dmesg output and that’s what I’ve got.
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.10-1-osmc (root@vero) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Mon Apr 6 15:34:17 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 809abd40, node_mem_map ae213000
[ 0.000000] Normal zone: 1504 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8640->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ae1e1000 s12096 r8192 d20672 u40960
[ 0.000000] pcpu-alloc: s12096 r8192 d20672 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 191008
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1312 bcm2708_fb.fbheight=736 bcm2709.boardrev=0xa01041 bcm2709.serial=0xd94e1201 smsc95xx.macaddr=B8:27:EB:4E:12:01 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p6 osmcdev=rbp2 rootfstype=ext4 rootwait quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 744108K/770048K available (7245K kernel code, 401K rwdata, 1864K rodata, 392K init, 763K bss, 25940K reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x808ed900 (9111 kB)
.init : 0x808ee000 - 0x80950000 ( 392 kB)
.data : 0x80950000 - 0x809b461c ( 402 kB)
.bss : 0x809b461c - 0x80a734d4 ( 764 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000015] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000038] Switching to timer-based delay loop, resolution 52ns
[ 0.000322] Console: colour dummy device 80x30
[ 0.000527] console [tty0] enabled
[ 0.000553] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000579] pid_max: default: 32768 minimum: 301
[ 0.000968] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000991] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002212] Initializing cgroup subsys memory
[ 0.002265] Initializing cgroup subsys devices
[ 0.002291] Initializing cgroup subsys freezer
[ 0.002316] Initializing cgroup subsys net_cls
[ 0.002349] Initializing cgroup subsys blkio
[ 0.002429] CPU: Testing write buffer coherency: ok
[ 0.002507] ftrace: allocating 18147 entries in 54 pages
[ 0.046183] CPU0: update cpu_capacity 1024
[ 0.046223] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.046240] [bcm2709_smp_prepare_cpus] enter
[ 0.046380] Setting up static identity map for 0x6adf68 - 0x6adfc0
[ 0.106147] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.106452] CPU1: Booted secondary processor
[ 0.106461] [bcm2709_secondary_init] enter cpu:1
[ 0.106511] CPU1: update cpu_capacity 1024
[ 0.106519] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.126117] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.126369] CPU2: Booted secondary processor
[ 0.126375] [bcm2709_secondary_init] enter cpu:2
[ 0.126405] CPU2: update cpu_capacity 1024
[ 0.126413] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.146150] [bcm2709_boot_secondary] cpu:3 started (0) 16
[ 0.146387] CPU3: Booted secondary processor
[ 0.146394] [bcm2709_secondary_init] enter cpu:3
[ 0.146424] CPU3: update cpu_capacity 1024
[ 0.146432] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.146523] Brought up 4 CPUs
[ 0.146557] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.146568] CPU: All CPU(s) started in SVC mode.
[ 0.147558] devtmpfs: initialized
[ 0.171401] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.173432] pinctrl core: initialized pinctrl subsystem
[ 0.176363] NET: Registered protocol family 16
[ 0.181707] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.205954] cpuidle: using governor ladder
[ 0.235978] cpuidle: using governor menu
[ 0.236115] bcm2709.uart_clock = 3000000
[ 0.238920] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.238940] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.238973] mailbox: Broadcom VideoCore Mailbox driver
[ 0.239083] bcm2708_vcio: mailbox at f300b880
[ 0.239428] bcm_power: Broadcom power driver
[ 0.239448] bcm_power_open() -> 0
[ 0.239460] bcm_power_request(0, 8)
[ 0.740125] bcm_mailbox_read -> 00000080, 0
[ 0.740138] bcm_power_request -> 0
[ 0.740255] Serial: AMBA PL011 UART driver
[ 0.740390] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.808515] SCSI subsystem initialized
[ 0.808769] usbcore: registered new interface driver usbfs
[ 0.808888] usbcore: registered new interface driver hub
[ 0.809036] usbcore: registered new device driver usb
[ 0.810680] Switched to clocksource arch_sys_counter
[ 0.838995] FS-Cache: Loaded
[ 0.839326] CacheFiles: Loaded
[ 0.851087] NET: Registered protocol family 2
[ 0.852421] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.852566] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.852760] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.852869] TCP: reno registered
[ 0.852893] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.852956] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.853440] NET: Registered protocol family 1
[ 0.853872] RPC: Registered named UNIX socket transport module.
[ 0.853890] RPC: Registered udp transport module.
[ 0.853900] RPC: Registered tcp transport module.
[ 0.853911] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.854364] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.854585] bcm2708_dma: DMA manager at f3007000
[ 0.854759] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.856380] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.856593] audit: initializing netlink subsys (disabled)
[ 0.856657] audit: type=2000 audit(0.829:1): initialized
[ 0.872454] VFS: Disk quotas dquot_6.5.2
[ 0.872832] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.875752] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.876766] NFS: Registering the id_resolver key type
[ 0.876876] Key type id_resolver registered
[ 0.876889] Key type id_legacy registered
[ 0.877917] msgmni has been set to 1469
[ 0.879871] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.880077] io scheduler noop registered
[ 0.880386] io scheduler bfq registered (default)
[ 0.880397] BFQ I/O-scheduler version: v7r7
[ 0.882875] BCM2708FB: allocated DMA memory eec00000
[ 0.882916] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.899324] Console: switching to colour frame buffer device 164x46
[ 0.910415] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 0.910749] uart-pl011 dev:f1: no DMA platform data
[ 0.911243] vc-cma: Videocore CMA driver
[ 0.911258] vc-cma: vc_cma_base = 0x00000000
[ 0.911271] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.911282] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.922737] brd: module loaded
[ 0.928529] loop: module loaded
[ 0.928837] vchiq: vchiq_init_state: slot_zero = 0xae800000, is_master = 0
[ 0.929642] Loading iSCSI transport class v2.0-870.
[ 0.930555] usbcore: registered new interface driver smsc95xx
[ 0.930630] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.131052] Core Release: 2.80a
[ 1.131074] Setting default values for core params
[ 1.131100] Finished setting default values for core params
[ 1.331505] Using Buffer DMA mode
[ 1.331522] Periodic Transfer Interrupt Enhancement - disabled
[ 1.331533] Multiprocessor Interrupt Enhancement - disabled
[ 1.331544] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.331562] Dedicated Tx FIFOs mode
[ 1.331935] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xaec14000 dma = 0xeec14000 len=9024
[ 1.331976] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.332001] dwc_otg: Microframe scheduler enabled
[ 1.332070] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x804f836c
[ 1.332090] WARN::hcd_init_fiq:413: FIQ ASM at 0x804f86dc length 36
[ 1.332110] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf80a000
[ 1.332138] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.332190] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.332238] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.332291] Init: Port Power? op_state=1
[ 1.332302] Init: Power Port (0)
[ 1.332605] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.332626] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.332643] usb usb1: Product: DWC OTG Controller
[ 1.332658] usb usb1: Manufacturer: Linux 3.18.10-1-osmc dwc_otg_hcd
[ 1.332673] usb usb1: SerialNumber: bcm2708_usb
[ 1.333681] hub 1-0:1.0: USB hub found
[ 1.333747] hub 1-0:1.0: 1 port detected
[ 1.334286] dwc_otg: FIQ enabled
[ 1.334299] dwc_otg: NAK holdoff enabled
[ 1.334309] dwc_otg: FIQ split-transaction FSM enabled
[ 1.334349] Module dwc_common_port init
[ 1.334725] usbcore: registered new interface driver usb-storage
[ 1.334994] mousedev: PS/2 mouse device common for all mice
[ 1.335901] bcm2835-cpufreq: min=600000 max=900000
[ 1.336216] sdhci: Secure Digital Host Controller Interface driver
[ 1.336229] sdhci: Copyright© Pierre Ossman
[ 1.336408] DMA channels allocated for the MMC driver
[ 1.370713] Load BCM2835 MMC driver
[ 1.371010] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.375878] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.378227] hidraw: raw HID events driver © Jiri Kosina
[ 1.378544] usbcore: registered new interface driver usbhid
[ 1.378557] usbhid: USB HID core driver
[ 1.379939] TCP: cubic registered
[ 1.379962] Initializing XFRM netlink socket
[ 1.380001] NET: Registered protocol family 17
[ 1.380164] Key type dns_resolver registered
[ 1.382495] Registering SWP/SWPB emulation handler
[ 1.386656] registered taskstats version 1
[ 1.390237] vc-sm: Videocore shared memory driver
[ 1.390257] [vc_sm_connected_init]: start
[ 1.391159] [vc_sm_connected_init]: end - returning 0
[ 1.392195] Waiting for root device /dev/mmcblk0p6…
[ 1.420225] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.423785] mmc0: new high speed SDHC card at address aaaa
[ 1.424369] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[ 1.429222] mmcblk0: p1 p2 < p5 p6 p7 p8 > p3
[ 1.510292] EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[ 1.510315] EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[ 1.530853] Indeed it is in host mode hprt0 = 00021501
[ 1.710789] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.710972] Indeed it is in host mode hprt0 = 00001101
[ 1.732001] EXT4-fs (mmcblk0p6): recovery complete
[ 1.740263] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 1.740338] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[ 1.742500] devtmpfs: mounted
[ 1.743165] Freeing unused kernel memory: 392K (808ee000 - 80950000)
[ 1.911122] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.911149] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.912163] hub 1-1:1.0: USB hub found
[ 1.912284] hub 1-1:1.0: 5 ports detected
[ 2.190950] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.291154] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.291185] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.294295] smsc95xx v1.0.4
[ 2.354600] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4e:12:01
[ 2.430981] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[ 2.537350] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b
[ 2.537381] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.537398] usb 1-1.4: Product: USB Receiver
[ 2.537414] usb 1-1.4: Manufacturer: Logitech
[ 2.545686] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C52B.0001/input/input0
[ 2.546044] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-bcm2708_usb-1.4/input0
[ 2.553877] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input1
[ 2.554821] hid-generic 0003:046D:C52B.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-bcm2708_usb-1.4/input1
[ 2.564253] hid-generic 0003:046D:C52B.0003: hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-bcm2708_usb-1.4/input2
[ 2.640945] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
[ 2.751904] usb 1-1.5: New USB device found, idVendor=148f, idProduct=7601
[ 2.751935] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.751952] usb 1-1.5: Product: 802.11 n WLAN
[ 2.751967] usb 1-1.5: Manufacturer: MediaTek
[ 2.751982] usb 1-1.5: SerialNumber: 1.0
[ 2.991012] usb 1-1.2: new low-speed USB device number 6 using dwc_otg
[ 3.112336] usb 1-1.2: New USB device found, idVendor=0518, idProduct=0002
[ 3.112366] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.112383] usb 1-1.2: Product: USB-compliant keyboard
[ 3.364885] random: systemd urandom read with 90 bits of entropy available
[ 3.431342] NET: Registered protocol family 10
[ 3.938244] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.938536] systemd[1]: Found ordering cycle on basic.target/start
[ 3.938568] systemd[1]: Found dependency on sysinit.target/start
[ 3.938597] systemd[1]: Found dependency on rpcbind.service/start
[ 3.938626] systemd[1]: Found dependency on network-online.target/start
[ 3.938654] systemd[1]: Found dependency on connman-wait-for-network.service/start
[ 3.938679] systemd[1]: Found dependency on basic.target/start
[ 3.938706] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 3.938737] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.939079] systemd[1]: Found ordering cycle on basic.target/start
[ 3.939112] systemd[1]: Found dependency on sysinit.target/start
[ 3.939141] systemd[1]: Found dependency on kbd.service/start
[ 3.939170] systemd[1]: Found dependency on remote-fs.target/start
[ 3.939196] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 3.939222] systemd[1]: Found dependency on connman.service/start
[ 3.939247] systemd[1]: Found dependency on basic.target/start
[ 3.939273] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 3.939303] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 4.096248] fuse init (API version 7.23)
[ 4.194584] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 4.496920] systemd-udevd[131]: starting version 215
[ 4.767224] random: nonblocking pool is initialized
[ 4.898098] input: USB-compliant keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0518:0002.0004/input/input2
[ 4.898998] ezkey 0003:0518:0002.0004: input,hidraw3: USB HID v1.10 Keyboard [USB-compliant keyboard] on usb-bcm2708_usb-1.2/input0
[ 4.901019] input: USB-compliant keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:0518:0002.0005/input/input3
[ 4.902062] ezkey 0003:0518:0002.0005: input,hidraw4: USB HID v1.10 Device [USB-compliant keyboard] on usb-bcm2708_usb-1.2/input1
[ 5.404053] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.221604] systemd-journald[104]: Received request to flush runtime journal from PID 1
[ 6.415359] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 6.415966] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.961088] FAT-fs (mmcblk0p7): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.065809] EXT4-fs (mmcblk0p8): recovery complete
[ 7.065843] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
[ 7.157251] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.256492] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 8.002429] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.004502] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 8.025529] 8021q: 802.1Q VLAN Support v1.8
[ 11.754421] Console: switching to colour dummy device 80x30
Thank you.
