Hi I have recently purchased rasberry pi 3b+
And installed osmc trying to watch DRM free venom HD from my nas via upn and I get no image or sound if i connect external USB harddrive it plays fine but not from nas i press control and zero and when streaming from nas the figure is 0. But from USB harddrive the percentage is 100. No licenses have been purchased yet
enable component-specific logging for all components
enable event logging and notification event logging
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
OSMC skin screenshots:
Thank you. I have to same problem with kodi on windows it will play some HD movies from my nas but other it won’t buffers for ages then shows some video and buffers again example
Blue ray ripped DVD the Martian plays fine iTunes venom with DRM removed playa fine via VLC and plex app but on kodi or osmc does not play is it worth buying the licences. My nas is a wd mycloud home. Or trying fstab
